1 - 3 of 3 Posts
so I have a 06 tuscani that has blown the snsr fuse im getting no spark swapped the fuse flipped the ignition over to on and had a ton of clicking coming from the underwood fuse panel then attempted to start the car and the snsr fuse blew again found some wires to the lower 02 sensor where chewed up a bit touching the cv axle my question is I just put led bulbs in the headlights with no decoder could this be causing me issues with snsr fuse or is this more than likely the lower 02 sensor any suggestions would be greatly appreciated my dad and I assumed the engine had jumped time only to research and find this fuse could be causing the lack of spark?
Not likely the headlights, probably that O2 sensor wiring is shorting on something and causing the fuse to blow.
1 - 3 of 3 Posts
