1 - 3 of 3 Posts
Does anyone know of any manufacturers that make a Stainless Steel Hydraulic Clutch Line for a RD Tiburon (2000)?
I had the same issue finding one for my 2006 Tiburon and saw that H.E.L's line for the 350z is an exact fit.
Any help would be greatly appreciated.
Rockauto uses the same part number for the slave cylinder for a 2000 and a 2004 (I recently installed a HEL line on my 04) so you know that at least the end with the banjo bolt will fit. Assuming you have the same type of hard line connecting the other end on your 2000 it should fit perfectly fine. I have a bunch of pictures from my install if you need some to compare.
1 - 3 of 3 Posts
