I just had a CM Stage 2 and Fidanza HY5 installed for my 03 6spd tib (Build Date 04/03). When I start it up, I hear like a grinding/shrieking noise. It sounds like the flywheel and starter hit each other or something. My mechanic said he had the same sound when he did his clutch/flywheel install for his prelude and it went away after a little bit. He says that the Fidanza doesnt mate with the OEM starter so thats why there is noise but will go away. Is this ok? Should there be no startup noises. Do you think the flywheel is not properly torqued? I wonder why it made noises. I had a clutch put on before(centerforce w/fidanza) and heard the same noise, so I took it off immediately and had them put the stocker back on a long time ago because I was afraid of the noise.
