1 - 3 of 3 Posts
ok, so heres the jist, i have a 1998 Dakota rt, trying to put a pioneer deck in, i've done lots of these, but for some reason i can not get the speakers to work! i hard wired a speaker to the deck and it works fine. I matched the wire to wire diagram and it should work. There are two empy spaces one for "mute" and one for "park" that are not attached to anything. I'm thinking this might be my problem. I have power and everything but the speakers work, tried testing with a battery and can not get the speakers to kick. any thoughts?
might have a factory amp?
did you tape the mute and the park leads off? if the mute wire is being grounded that may be where your problem is.
Oh and check to see if its set on amp cancel in the settings. if its on you wont be able to get any sound through the speakers
1 - 3 of 3 Posts
