1 - 3 of 3 Posts
I already bought a wide band gauge kit, also have an Alpine stage 1 kit, I am trying to figure out if I can put the wide band sensor in the stock header, I could remove the header (PITA), weld a bung on, cast iron is tricky to weld, OR remove both sensors from the front header, put the top one in the bottom, tie the bottom one up out of the way, and put the wide band sensor in the top?! I know the two sensors read the difference to each other, so one in the exhaust and one in the air should work, but do both the front and rear banks read against each other? Yeah I know just put headers on, I will eventually when the bucks get freed up, X-mas was just here ya know!
Discussion Starter · #2 ·
Ahh come on, somebody must have some experience with this, help a brother out!
it should work fine....just use it precat not post
1 - 3 of 3 Posts
