1 - 13 of 13 Posts
Would it hurt anything to put on front and rear strut bars and rear sway bar?
not hurt but help ALOT! only issue people have with sway bars is if u run th hard of a setting it can snap the tabs on the stock struts and u have to get them welded back on. I ran mine on soft for awhile and no issues even with mountain runs
Aside from causing premature balding of the front tires and uneven wear patterns on the rear ones, front cv joint damage and rear hemmoroidal discomfort.............. no problems at all.
Thanks for the comments after reading comments through search about different setups etc, I just ordered the RRM front and rear stut bars and will be getting the sway bar in a few weeks.
Yes actually it can. It can hurt your passengers stomach when you go around nice twisty turns without the car flexing. (it kinda freaks them out a bit)
is the rear strutbar helping much? i have the front and fear the rear sturbar won't clear my sub case...
Sweet. Nice choice on the strut bars. The front one is the Easiest Install Ever. Rear is easy, but takes a little more time.
As for the rear sway bar, I heard they can break the tab on the stock struts, so I've stayed away from that mod.
Anyway, enjoy the corners :)
i ran the rear sway on soft and noticed a diffrence and went through 2 hard mountain runs and no tabs broke
Retired Staff | Track Rat
Strut bars were the first mod's I did, and seem to have been the most cost / benefit ratio products. Unless you drive miss daisy, you'll immediately notice. Have fun
That's funny, I installed front and rear RRM strut bars, and didn't notice a difference.
Now, when I put my Tein S-Techs on, THEN there was a big difference.....
1 - 13 of 13 Posts
