1 - 20 of 51 Posts
is the STS univesal turbo any good?.....it mounts right behind the rear axle......is it good or is it trash?...
edit....im having a hard time finding a turbo kit for my 2.7 tib besides the alpine or NGM stealth..
it doesnt?.......thats probably just for the i4 then.....that lowers me to hjust the stealth turbo.
any others?.....i heard the STS one is pretty decent......i just need to be pointed in the right direction....is there a garrett model that will fit on my 2.7?
yea the alpine is for the i4 only, but go with the stealth it the best and only kit made for the v6, thats the one im going with.
i know....i just wanna play the market a little.....i wanna see if there are other turbos available....
doesn't garrett make any good ones for the v6?...or do you have to alter them to get them to work?
You should do more research on the STS. Those kits are top notch, and making hella power. The base kit bolted up to an LS1 Camaro produces 100whp.... Although there is no STS for the Tib, it would be sure to make some serious power.
there's a universal turbo from STS that mounts near the rear axle......
http://www.ststurbo.com/universal_system
Discussion Starter · #9 ·
im thinking about doing custom so i can get more power....but wouldnt that just cost more for all the stuff separate?......
plus...im sorta iffy on that...as im still in the learning phase about how to build custom turbos..
Discussion Starter · #12 ·
do you guys think that would be better then the stealth nd garrett turbos?
Discussion Starter · #13 · (Edited)
click on installation picks link on the STS universal turbo..page.........i wanna do that rear axle twin turbo...lol..
edit......i was debating between assassin or a turbo......assassin would be an easier install..but its expensive as hell...and everyone on here has it...i wanna do something unique...
im probably gonna end up turbo.....STS seems pretty damn good so far...
I would try it out it looks like a pretty unique design, but you dont know how well the tib is going to react to a kit that is "universal" and not actually designed for a specific application. Do they have anything on the site like a dyno sheet of it working on a smaller displacement 6 cylinder motor.
Discussion Starter · #15 ·
how about garrett.....there's no 2.7l displacement turbocharger?....
i cant adjust a turbo for a diff displacement...like 2.0l or 3.0 l for the 2.7 v6 can i ?
Discussion Starter · #16 ·
That kit is crazy and all, but on the pics of the underbody of the Cobalt it looks like the Turbo pipe would drag if you went over a bump. Go with the Stealth, it is already done and no guess work on where to put stuff and R&D is done.
One question - If you have a rear axle turbo and the engine is in the front, wouldn't you get more lag due to the long lengths of all the tubes?
garrett does not make any turbo kits for our cars, you can buy a garrett turbo and make a custom system out of it, otherwise the only actual kit made for the 2.7 is the NGM stealth. i thought boostology was gonna make us one but i guess that fell through.
yup.
Discussion Starter · #19 ·
i was just thinking about the lag too.......is the piping what causes the lag?
there are HKS ball bearing turbos....based of the garrett turbos.....and they are universal...from the last link there
i dunno.....how much boost do you think the stealth can produce with a rebuilt bottom end .etc...
im shooting for big numbers......like around 380-400 hp...maybe even more....
The Stealth hit the 400 mark and kept going...
http://www.newtiburon.com/forums/showthread.php?t=70298
1 - 20 of 51 Posts
