1 - 6 of 6 Posts
i was wondering if 2003 tiburon aftermartket suspension springs will work on my 2008 tiburon
please let me know :)
thanks, Chris
i feel stupid for asking this but to lower it would i only need to change out the springs, or would i need to change out other stuff as well
well, to do everything right, i would deff get new struts. but, you can change out to aftermarket springs with stock struts. however, changing the springs will reduce the life on the OEM struts due to the new springs. i mean, if there alot of smooth streets around you, just change out the springs and keep the OEM struts. but persoanlly, id do the install once and just buy lowering springs as well as new struts (KYB GR2's or Koni's). good luck.
well thanks for the advice and help guys i dont make enough to buy new struts right now so im going to stick it out with the stock ones for a but i will change them out when i get the money, i need new tires and brakes and struts now haha great...
1 - 6 of 6 Posts
