1 - 1 of 1 Posts
Has anyone ever had the idea to, heat the tail lights up and pull them apart same way as the headlights are done, then paint the inside say all black except for the chrome plating inside the light bulb cavities? So that way when you look thru the red lenses there is black and chome inside the lights.
2003 gt 6 speed
raceland coilovers
z23 carbon fiber/ceramic brake pads
18x7.5 +40 offset MB Lovan wheels
225/40/17 tires
clear corner headlight mod
ebay short ram intake pipe w/ k&n filter
shark racing sts
torque solutions shift linkage bushings
aluminum shifter base bushings
slave cylinder mod
ngk wires and ngk laser iridium plugs
new stabilizer bar bushings and endlinks
new timing belt and water pump
new tps
new pcv
new idle air temp sensor and connector
new idle air control valve
1 - 1 of 1 Posts
