This is my first time working on taking the motor out of the car but I want to keep my tranny in I don't want it out just the engine is there a way I can just take out the engine or does the tranny have to come to
If it's a manual tiburon then the trans has to come with it you won't be able to get it out otherwise and it's not much harder to pull the transThis is my first time working on taking the motor out of the car but I want to keep my tranny in I don't want it out just the engine is there a way I can just take out the engine or does the tranny have to come to
Actually the engine only has 1 mount to it the transmission has 3 mounts on itGiven that the transmission is largely supported by the engine, I would think you'd have to pull it out with the engine. w/o the engine, it has a grand total of one mount holding it in place, so you'd need to make some kind of support for when the engine is removed.
I'd just remove the tranny with the engine, it's not much more work to pull the axles & shifter cables.
I literally just pulled my engine out of my tib, and I know for a fact the engine has 3 mounts and the transmission has 1. This goes for 03+ 2.0 & 2.7 models.Actually the engine only has 1 mount to it the transmission has 3 mounts on it
Nope it has 3 trans mount and only 1 mount that actually bolts to the engine . All 3 mounts bolt to the transmission and 1 to the engineI literally just pulled my engine out of my tib, and I know for a fact the engine has 3 mounts and the transmission has 1. This goes for 03+ 2.0 & 2.7 models.
I don't know what to tell you other than you're wrong.Nope it has 3 trans mount and only 1 mount that actually bolts to the engine . All 3 mounts bolt to the transmission and 1 to the engine
I literally pulled several motors out of these cars so I know . I literally just pulled one out of the junk yard today people call them motor mounts but they are actually transmission mounts lol, one in the rear of the transmission one in the front and one on topI don't know what to tell you other than you're wrong.
I know for a fact the 2.0 & 2.7 03-08 models have three engine mounts and 1 transmission mount. However, I cannot say for the RD (pre 2000s) tibs.
Please state the year, trim, and engine / trans type that supposidly has 3 transmission mounts and one engine mount if you wish to prove me wrong.
lol rushking is right. That's a trans mount... Bolts to the "bellhousing" if you want to call it that.I don't know what to tell you other than you're wrong.
What headers are those?lol rushking is right. That's a trans mount... Bolts to the "bellhousing" if you want to call it that.
Not my motor but looks to be either SSA or the Chinese knockoffs. Here is the video I got it the image from:What headers are those?
Lmao I admit it was pettyAnd btw why you guys fighting about engine mounts¿ who cares what you call them it’s a mount the engine is connected to the trans it’s basically all one big part so it all does the same thing hold your engine and trans up rightttt? And the bell housing is a bell housing not the motor and not the trans so your both wrong? Lol 😂 just agree to to agree that whatever they are called they do the same thing no matter what you call them 😘
You are Correct, I just did a Motor Swap on A 2003 tibb. 1 on The Transmission and 3 on da motor, " Front, Back, and Top Left of the Motor are your M.Mounts" Then 1 on the Top of The Transmission...I don't know what to tell you other than you're wrong.
lolwat? Let's put this argument to bed now. The front mount (radiator side) and rear (firewall side) mount both attach to the transmission directly. That means there are 3 trans mounts and 1 motor mount. The goal of these two mounts is to prevent engine/trans roll, so really it doesn't matter where they mount except in the OPs question it was relevant.1 on The Transmission and 3 on da motor, " Front, Back, and Top Left of the Motor are your M.Mounts" Then 1 on the Top of The Transmission...
