1 - 9 of 9 Posts
I was just wondering if I disconnect the return line to my transmission to install a cooler if the fluid would continue to drain or would it just drain the fluid in the line? Could I just reconnect the new line quickly if it continues to drain? Any help would be appreciated. I'm having my trans fluid changed them friday and figured this would be the best time to get it mounted and if have to install the thing completely.
Swim away fishes...
Yeah, the car's off so it won't empty.
just curious but how would you go about mounting one of these if you had a front mount intercooler?
would you mount it pretty much on top of the intercooler? but in that case you would have the radiator almost completely blocked off, wouldnt that cause any adverse affects?
Swim away fishes...
Get a smaller intercooler. :)
I guess you could stack it on the intercooler. Whether it causes heat issues would depend on the car.
I've seen them mounted below the radiator support, but it puts the cooler close to the ground.
1 - 9 of 9 Posts
