My 2.7 tib is supercharged, has headers (and muffler/cat delete with a glass pack), nkg plugs, wires, and coil pack, will be getting higher cc fuel injectors (I heard gtr injectors are plug and play?) And cold air intake. Should I get a tune on it? Or can my ecu handle it all?
What size supercharger pulley are you running now? That will determine if you need larger injectors and some way to control them. For a 3.4" pulley I recommend at least a 190lph fuel pump upgrade just to be safe. Any smaller pulley than that and you will need larger injectors and a tuning device. Nobody "tunes" the stock ECU anymore so you'r out of luck with that approach.
