1 - 5 of 5 Posts
In my 2007 i4 2.0 mannual I've been noticing some vibration going to my cabing esp. aroud idle and up to 1000 RPM. I'm suspecting motor mounts. It is up to level of certain panels resonating / rattling at speciffic RPMs.
So is there some motor mount kit you'd recommend?
Ideally I'd go OEM or equal but I'm having trouble identifying OEM part numbers so anyone know them?
It is 4 of them right and only transmission one is different MT/AT?
I did search and also looked at RockAuto but so many options there....
Thanks crew!
Any of the Rock Auto stuff should be oem equivalent, just make sure you select the right year+engine.
Thanks Itlump!
I did that, the only worry is that I can't select MT or AT so on some mounts it says for AT etc. well It's jut me, I'll manage.
Would you know If all 4 are responsible for vibration?
I would look at the mounts first before you go buying new ones. The main one that can cause excess vibration if broken is the liquid filled mount on the passenger side. The front and rear mounts are different between AT and MT I believe.
Discussion Starter #5
Will do, Thanks a lot DM!
1 - 5 of 5 Posts
