I recently started hearing a knocking noise coming from my engine. It seems to be the same knocking sound that a lot of other people on this forum have been wondering about, but never seem to report back on what the issue was.
TL;DR: there's a disconcerting knock coming from approximately the middle of the engine, initially only at low revs, but is now also audible at idle. Video of someone with that same sound:
Full story: I bought an '03 GT V6 Tiburon with 180k miles/294k km on the odo for 2500€ this February. When I got it, it seemed to be running fine, except for a belt squeal, electrical issues and various leaking gaskets, primarily valve covers.
I fixed the belt noise by installing a new Gates serp kit. Car seemed to run fine. I then parked it for about three months while I fixed various issues, including the valve cover gaskets, and installed new spark plugs and leads. When I initially got the car back together (still on the old oil), it seemed to run fine. However, when I started it up the next day and let it warm up, I started noticing a faint knocking noise at mild revs. I drove it for a bit, initially slowly and then using more of the rev range, the noise was not detectable above 2500 rpm or under 1500 rpm.
Thinking it could be a lazy lifter, I changed the oil (looked brown, not black) and added some LiquiMoly Hydraulic Lifter additive to the Valvoline 10W-40 I filled it with. I used an OEM Hyundai filter, the old one was by MannFilter. During this operation I found aluminum glitter/paste in the little groove of the oil cap hole (but none deeper in), and there was faint evidence of metal in the oil, too - the pan I drained the oil into wasn't clean to begin with, so I unfortunately can't be sure of how much metal there actually was. No evidence of glitter in the filter hole, but I've not yet autopsied it. I'll update the post once I get around to that.
After the oil change I took it for a spin, both slow and fast, hoping the situation would change. Indeed it did: the knocking is now detectable at idle.
Engine has no trouble revving, there's no new shaking or instability, just what I think is a harmonic vibration at about 2000 rpm.
To locate the source of the noise, I used a prybar as a stethoscope. I checked both valve covers, power steering pump, exhaust header, serp tensioner, alternator and AC compressor - all steady sounds. The noise was detectable but faint when the bar was against the engine block. The sound could be heard the best with the bar against the thermostat housing. With the naked ear, the sound seems to be coming from the timing belt area.
Speculation:
Looking around for others with the same issue, I found this video with the exact same noise as I'm experiencing:
It's that same sort of soft RPM related knocking that goes away completely at revs.
I'm going to try replacing the timing belt, pulleys, tensioner, mounts and installing the Valeo solid flywheel kit simply because I have the parts, to see if I find something or if the noise goes away, as a lot of suggestions have pointed to loose timing belt tensioner or DMF... But I'm also prepared to accept the fact that I spun some bearing or damaged the oil pump, so in the worst case I'll drive it around town until it breaks properly, after which I'll be storing the car until I get around to either rebuilding the engine or buying a new one.
And I'm quite determined to figure out what's causing this noise, so I'll be updating this post and thread as I gather data. I'll be able to go inspect the filter tomorrow evening.
If anyone knows something about this issue, I'd appreciate any and all insight.
Speculation:
- Could it have knocked before I got it? Perhaps, but I can't remember such a noise.
- Could I have gotten a piece of gasket silicone into an oil passage bad enough to starve a bearing of oil? Perhaps, but the same noise has been reported by others for the last 14 years, and in only one case valve cover work was involved.
- Could it be a spun crank bearing? Perhaps, but I'd have expected the engine to have seized or at least gotten noisy as hell at high RPM by now.
- Maybe I have too much oil in the engine and the crank is splashing into it a little? The dipstick got hard to read, though I think I was just slightly past the full dot, so.. if I'm off on the measurement, there is a chance I'm off on the oil contents, but at worst I'm 3 dl (about a third of a quart) over.
