I purchased the motor mount inserts from Speed Freak Racing and went to install the front mount. Everything went together, until I put the mount in and can't Get the bolt to go through anyone have any suggestion?
yeah try putting it in gear or reverse or something cuz when u do that with the motor on u know the engine will shift and u can put the bolt in
I used a drift punch for the rear one. The rear one has an off-cenetered hole, but the front is centered, and mine went right in. Take a punch or heavy screwdriver and and use it to line up one side and slap the bolt in the other. If the engine's setting too low w/o the mount in (which it probably is), then use a floor jack to raise it enough to get the bolt in.
Sorry, I don't mean to hijack this thread, but if I were to replace one of my motor mounts, which would be the best to replace? This helps to eliminate wheel hop correct? So is the front mount the one to replace?
I just realized that you said "inserts". Did you mean "bushings"? Inserts suck and will come undone. Bushing are the whole poly piece that replaces the oem bushing. If you bought inserts, I'd send them back.
Okay, those are bushings. The inserts are the notched pieces that fit in with your oem mounts.
Look through the side of the hole and make sure the engine has dropped too low to insert the bolt. If so, carefully put a block of wood under the block on the floor jack in clear location where it won't break anything, and not the pan. You should obnny have raise it slightly to line up the mount. Don't overdo it.
Thank you everyone for your help, 2 pumps of the jack and the bolt slid right in!! :3_nosthum
Related Threads
Hyundai Tiburon Forums
3.2M posts
57.7K members
Since 2004
