Yes, I searched. No, I did not find it.
1. Do your parking lights and interior lights flash off and on at about 3 second intervals when you remote start the car? They go off when I put the key in the ignition. Is this normal?
2. I have to literally jump on the car just for the shock sensor to warn. It is currently zip-tied to the metal bar that holds the BCM. I know it should be hooked to a wiring harness, but what I need to know is a) which way to turn the sensor's knob and b) whether I need to restart the car for it to "reset" or not. What are the sensitivity of your sensors like. Will it go off if I push your trunk down?
3. Is there anything else I can connect to the system? Currently I have my trunk pop hooked to the AUX output, but I noticed that there are two more outputs. Does anyone have their rear defroster hooked up? Or is there anything else I can hook up?
4. Does anyone have a microwave/proximity sensor hooked up? I know they are for convertibles, but has anyone gotten one to work on the Tib? Someone recently stole my antenna and I would like that extra security when I leave it for long periods of time.
Thanks everyone!
Paul
Thanks everyone!
Paul
