1 - 5 of 5 Posts
i noticed after it rains that ill have water in my spare tire well anyone else have this problem? how do u fix it ? thanks
there are grommets under the tire that lead to the outside of the car, i bet one is loose or even missing.
Chase
Check and find out.
It comes from the gutters in the sun roof, I had to take off my roof lining and rear side panel to re seal the end of the gutter with silicone "were the exit hose plugs in the gutter"
Also make sure the hose on the driver side is long enough to reach the hole in the rear fender
thank you will go check both those out tommorow since its dark now and i dont have a garage to work in :-(
thanks again
1 - 5 of 5 Posts
