1 - 20 of 28 Posts
What is a Turbo Charger:
A turbocharger is an exhaust gas-driven compressor used to increase the power output of an internal-combustion engine by compressing air that is entering the engine thus increasing the amount of available oxygen. A key advantage of turbochargers is that they offer a considerable increase in engine power with only a slight increase in weight.
Principle of Operation:
A turbocharger is a dynamic compressor, in which air or gas is compressed by the mechanical action of impellers, vaned rotors which are spun using the kinetic movement of air, imparting velocity and pressure to the flowing medium.
The mechanical concept turbocharger revolves around three main parts. A turbine is driven by the exhaust gas from a pump, most often an internal combustion engine, to spin an impeller whose function is to force more air into the pump's intake, or air supply. The third basic part is a center hub rotating assembly (CHRA) which contains bearing, lubrication, cooling, and a shaft that directly connects the turbine and impeller. The shaft, bearing, impeller, and turbine can rotate at speeds in the tens or hundreds of thousands of RPM (revolutions per minute).
The lubrication system can be either a closed system or be fed from the engine's oil supply. The lubrication system may double as the cooling system, or separate coolant may be pumped through the center housing from an outside source. Oil lubrication and water cooling using engine oil and engine coolant are commonplace in automotive applications.
The turbine and impeller are each contained within their own folded conical housing on opposite sides of the center hub rotating assembly. These housings collect and direct the gas flow. The size and shape can dictate some performance characteristics of the overall turbocharger. The area of the cone to radius from center hub is expressed as a ratio (AR, A/R, or A:R). Often the same basic turbocharger assembly will be available from the manufacturer with multiple AR choices for the turbine housing and sometimes the compressor cover as well. This allows the designer of the engine system to tailor the compromises between performance, response, and efficiency to application or preference. Both housings resemble snail shells, and thus turbochargers are sometimes referred to in slang as snails.
By spinning at a relatively high speed the compressor turbine draws in a large volume of air and forces it into the engine. As the turbocharger's output flow volume exceeds the engine's volumetric flow, air pressure in the intake system begins to build, often called boost. The speed at which the assembly spins is proportional to the pressure of the compressed air and total mass of air flow being moved. Since a turbo will spin to RPMs far beyond what is needed or of what it is mechanically capable of, the speed must be controlled, and thus is also the property used to set the desired compression pressure. A wastegate is the most common mechanical control system and is often further augmented by an electronic boost controller.
The implementation of a turbocharger is to improve upon the size to output efficiency of an engine by solving for one of its cardinal limitations. A naturally aspirated automobile engine uses only the downward stroke of a piston to create an area of low pressure in order to draw air into the cylinder. Since the number of air and fuel molecules determine the potential energy available to force the piston down on the combustion stroke, and because of the relatively constant pressure of the atmosphere, there ultimately will be a limit to the amount of air and consequently fuel filling the combustion chamber. This ability to fill the cylinder with air is its volumetric efficiency. Since the turbocharger increases the pressure at the point where air is entering the cylinder, and the amount of air brought into the cylinder is largely a function of time and pressure, more air will be drawn in as the pressure increases. The intake pressure, in the absence of the turbocharger determined by the atmosphere, can be controllably increased with the turbocharger.
The application of a compressor to increase pressure at the point of cylinder air intake is often referred to as forced induction. Centrifugal superchargers operate in the same fashion as a turbo; however, the energy to spin the compressor is taken from the rotating output energy of the engine's crankshaft as opposed to exhaust gas. For this reason turbochargers are ideally more efficient, since their turbines are actually heat engines, converting some of the heat energy from the exhaust gas that would otherwise be wasted, into useful work. Superchargers use output energy to achieve a net gain, which is at the expense of some of the engine's total output.
Discussion Starter #2
Re: What is a Turbocharger (Introduction Info)
What is Lag:
A lag is sometimes felt by the driver of a turbocharged vehicle as a delay between pushing on the accelerator pedal and feeling the turbo kick-in. This is symptomatic of the time taken for the exhaust system driving the turbine to come to high pressure and for the turbine rotor to overcome its rotational inertia and reach the speed necessary to supply boost pressure. The directly-driven compressor in a positive-displacement supercharger does not suffer this problem. (Centrifugal superchargers do not build boost at low RPMs like a positive displacement supercharger will). Conversely on light loads or at low RPM a turbocharger supplies less boost and the engine is more efficient than a supercharged engine.
Lag can be reduced by lowering the rotational inertia of the turbine, for example by using lighter parts to allow the spool-up to happen more quickly. Ceramic turbines are a big help in this direction. Unfortunately, their relative fragility limits the maximum boost they can supply. Another way to reduce lag is to change the aspect ratio of the turbine by reducing the diameter and increasing the gas-flow path-length. Increasing the upper-deck air pressure and improving the wastegate response helps but there are cost increases and reliability disadvantages that car manufacturers are not happy about. Lag is also reduced by using a foil bearing rather than a conventional oil bearing. This reduces friction and contributes to faster acceleration of the turbo's rotating assembly.
Another common method of equalizing turbo lag is to have the turbine wheel "clipped", or to reduce the surface area of the turbine wheel's rotating blades. By clipping a minute portion off the tip of each blade of the turbine wheel, less restriction is imposed upon the escaping exhaust gases. This imparts less impedance onto the flow of exhaust gases at low RPM, allowing the vehicle to retain more of its low-end torque, but also pushes the effective boost RPM to a slightly higher level. The amount a turbine wheel is and can be clipped is highly application-specific. Turbine clipping is measured and specified in degrees.
Other setups, most notably in V-type engines, utilize two identically-sized but smaller turbos, each fed by a separate set of exhaust streams from the engine. The two smaller turbos produce the same (or more) aggregate amount of boost as a larger single turbo, but since they are smaller they reach their optimal RPM, and thus optimal boost delivery, faster. Such an arrangement of turbos is typically referred to as a parallel twin-turbo system.
Some car makers combat lag by using two small turbos (such as Toyota, Subaru, Maserati, Mazda, and Audi). A typical arrangement for this is to have one turbo active across the entire rev range of the engine and one coming on-line at higher RPM. Early designs would have one turbocharger active up to a certain RPM, after which both turbochargers are active. Below this RPM, both exhaust and air inlet of the secondary turbo are closed. Being individually smaller they do not suffer from excessive lag and having the second turbo operating at a higher RPM range allows it to get to full rotational speed before it is required. Such combinations are referred to as a sequential twin-turbo. Sequential twin-turbos are usually much more complicated than a single or parallel twin-turbo systems because they require what amounts to three sets of pipes-intake and wastegate pipes for the two turbochargers as well as valves to control the direction of the exhaust gases. An example of this is the current BMW E60 5-Series 535d. Many new diesel engines use this technology to not only eliminate lag but also to reduce fuel consumption and produce cleaner emissions.
Lag is not to be confused with the boost threshold; however, many publications still make this basic mistake. The boost threshold of a turbo system describes the minimum turbo RPM at which the turbo is physically able to supply the requested boost level. Newer turbocharger and engine developments have caused boost thresholds to steadily decline to where day-to-day use feels perfectly natural. Putting your foot down at 1200 engine RPM and having no boost until 2000 engine RPM is an example of boost threshold and not lag.
Race cars often utilise anti-lag to completely eliminate lag at the cost of reduced turbocharger life.
Be careful Derek. If you post something like this which you obviously didn't write you need to give credit to whatever source you got if from. Otherwise if the original Author sees it he/she can sue you for plagiarism.
^^^^^^^clank Clank Clank
Hoorary for Wikipedia!
-BRR
Discussion Starter #6
I thought I posted the link on the 2nd post. Found it on
http://en.wikipedia.org/wiki/Turbocharger
You be suprised what you find on there. Too bad "everyone" can post on it which sometimes makes me question the "reliability" of the information. But I thought those paragraphs gave a great intro.
staw512 said:
4xx<12xx<55xx
<--8xxx
what now huh :3_fyou :3_winkthu
i had to put 3 x's cause i cant keep up with my post count it changes daily...
like just yesturday it was in the 84xx's i look today, 85xx's lol
sheesh
and i havent really been that active lately.. :3_redcard
deez, man calm down, all he does on forum is provocate people to flame and offend himself .. not the most interesting type of people.
antiquity said:
you guys should try to keep up too.
you should cut that gigantic sig in half
1 - 20 of 28 Posts
