641RJX said:
How easy would it be or not to put the stock mufflers back on if I hate the sound??
The best way to find out is to just take the muffler section off your car and drive it around like that for a couple days.
You can do this very easily(or not) depending on how many miles you have on your car and just how rusted the bolts on the exhaust system are.
There is a flange right in front of the rear axle on the passanger side that connects the mid pipe to the exhaust section. You can just unbolt it there and take down the muffler section. I have a feeling you will like it, i did. That part is basically free power. You will see just how restrictive the back section of our exhausts are.
After that if you want to pipe it out you can take it to an exhaust shop and have them run some back for you.
This process is all completely reversible of you dont like the sound by just bolting the muffler section back on. I would suggest replacing the gasket at that connection if you put it back together as mine basically jsut fell apart when i took the sections apart. Of course i have 4 winters and 80k miles on my car too.
Also when you do this make sure you keep an eye on your revs if you are a manual, when mine was off i was able to over rev the hell out of my car to the point i got a CEL. Of course i was on a closed track at the time. :3_winkthu
