1 - 7 of 7 Posts
Will a 215 60 r16 tire fit and if not could I use 16 inch rims , what size tires would work
Your suggested 215/60-16 tire will ONLY fit on a 16" rim.....
A 16" rim may clear stock brakes, but likely not over a "BBK" or larger rotors.
Super Moderator
In my experience 16" wheels have fit all stock Tiburon brake applications. I have had 16" steelies on with my larger XG350 brakes on, even. I have the impression that the OP is not necessarily looking to make modifcations but likely came across a good deal on those 215/60 tires. I can check but I really doubt they will fit (too big).
What wheel/tire sizes are best? OEM spec as stated above for most situations. Unless you want to start modding and then you'll run into more issues.
1 - 7 of 7 Posts
