1 - 3 of 3 Posts
ok so i might be getting some 18'' wheels pretty soon, my question is what offsets can i get so my wheels wont rub, what offset is just perfect for the tib? whats the safest offset? thanks an advance for any info -thanks
35-40mm works fine with a 8" wide rim
are you lowered? do you plan to lower the car? if you're lowered or want to eventually become lowered you'll certainly need to roll your fenders with a 35 offset, but it's going to be perfectly flush with the fenders. 40 offset will obviously sit in a bit more, but may also require rolling of fenders depending on the tires chosen. if you're staying stock height i've seen as low as 25 offset without issue.
1 - 3 of 3 Posts
