1 - 6 of 6 Posts
Was gonna get a spare OEM throttle body to get ported.
However, the only new ones I can find are not cruise control compatible (as these are coming from Korea a market where apparently cruise wasn't offered).
My Tiburon does have cruise control, however, I have since unplugged and removed the assembly. Can I run a non-cruise TB? Or are there other differences?
2006 Hyundai Tiburon SE
They are compatible on the 2.7L.
Porting your TB won't make much for gains. The limit on the 2.7L TB is about 58-59mm. That's only 2-3mm over the stock size of 56mm. I know that maxbore.com sets their limit at 58mm because of problems going larger. It's like a 50/50 chance the casting was poorly done and had thinner walls. The porting services that go go bigger than 58mm either cast their own throttle bodies from a fresh casting or added material to the IAC port like in the case of the tigerlilly throttle bodies.
Cool, just wanted to verify before getting a new one.
I understand the porting yields minimal gains, but while I sort through the issues of my NGM 70mm I'll settle for a ported stock for now. Throttle response with the stock unit just feels very bottlenecked right before 3000rpm which wasn't the case with the NGM setup.
Ahhh I see. That NGM probably needs new seals and bearings if you're having trouble with idle. Did you buy that 70mm from John D by chance?
Negatory. From someone else. I believe it was an issue with the casting of the unit itself specifically where the TPS snaps into. Caused a sticky throttle eachtime the foot was applied to the pedal and caused the car to idle at 1500rpm when in neutral and rolling to a stop. Haven't messed with it much sense then.
Hoping that a ported tb will mitigate the bottlenecking so that the rest of the NGM setup can breathe more efficiently. Just wanted a verify before I snagged a new OEM tb from Albert Hwang.
1 - 6 of 6 Posts
