1 - 7 of 7 Posts
With the oil filter for the i4 fit the v6? I know thats an odd question, but I found this but its for the v6:
2003 Hyundai Tiburon
Engine Oil Cooler
Brand: Flexalite
FLEXALITE-OIL COOLER SANDWICH ADAPTER KIT - Allows A Pressurized Mounting Point For Oil Cooler Lines Without Relocating The Oil Filter, Oil Filter Mount Adapter Thread Size 20mm x 1.5", Thickness 1", O-Ring 2 1/2"
Are the oil filters for the v6 and i4 the same threading?
If im not mistaken they will.
check with your dealership they can tell you for sure.
i have a 2.0 and today bought an original hyundai oil filter. there is 26300 35502 written on it and B17003H(poland part number)
All the Hyundai oil filters are exactly the same unless you have the 3.3L V6 or the 3.8L V6. Everything prior to that was the same.
the v6 filter fits the 4cyl, so i assume it works in reverse at least coupling wise, the problem could be how far out the filter sticks
the v6 filter is stubbier than the i4s
thats a pretty sweet idea , i give him a gold star for effort .
hook it up , test drive it for 3000 miles , change yer oil ,test drive another 300o miles ,change yer oil and if all is well peice together a kit and put it on ebay as being the ONLY oil cooler kit desinged for the 2.0 tibby
1 - 7 of 7 Posts
