Coutesy of OZTuscani
Tools Needed:
Pliers
Ratchet
10mm Socket
12mm Socket
This DIY assumes you have already removed the Throttle Body & Upper Intake Manifold (which I covered in different DIYs). My pics show the Lower Intake Manifold removed as well, that is not necessary to just remove the valve covers.
REAR VALVE COVER REMOVAL
Since it is hardest, we will start with the valve cover in the back. First, remove the 3 plug wires from the valve cover (remember where they go!). If you do not have Hotwires installed you will not have to worry about unbolting the grounding straps.
Now remove the vacuum hose attached to the right side of the valve cover (1) & the hose connected to both valve covers (2). You can also remove the hose connected to the front valve cover to get it out of the way (3).
You are now ready to remove the 2 – 10mm bolts that attach the timing belt cover to the top of the valve cover. You will also need to remove the large black bracket (with foam padding attached) sticking up behind the valve cover (seen better in photo 1). There are 3 – 12mm bolts holding it on below the valve cover, you can’t see them & have to feel for them. This can be somewhat difficult, but it makes removing the valve cover much easier.
Now remove the 8 – 10mm valve cover bolts and remove the valve cover (pry gently with screwdriver if needed). When lifting the valve cover off, make sure the gasket either stays on the head or comes off with the valve cover.
FRONT VALVE COVER REMOVAL
After the rear valve cover removal, this is a piece of cake! Again, remove the 3 plug wires (noting where they go).
Remove the 2 – 10mm bolts that attach the timing belt cover to the top of the valve cover.
If you are not ready to reinstall everything, I recommend covering everything up.
Here is what it looks like with both valve covers & the intake manifold removed. It is recommended to replace the gaskets since they are rubber (Cost about $30 pair from Dealer.)
VALVE COVER REINSTALLATION
OK, now we are ready to reinstall the new valve covers! First you will want to make sure any fittings you may have removed from the old valve covers are reinstalled into the new ones. As mentioned before, you should have a set of NEW valve cover gaskets for the reinstall.
We will start with the rear valve cover. As a precaution (and completely optional) I am going to place a bead of gasket silicone on the head itself. Paying particular attention to each end where you will see a semi-circular hump & depression. The last thing you want to do is get everything back together and have a leak (especially the rear). First, flip the valve cover upside down and install the gasket, pressing it into the lip. If you find the gasket does not want to stay pressed in, you can use some silicone to help hold it. Next, place the bead of silicone on the head where the gasket will sit.
Now you are ready to install the valve cover back on the head. Make sure the gasket is seated properly and then install the valve cover onto the head. It is a tight fit, & you kind of have to wiggle it into place. I found installing the end near the timing cover first was easier. Now you can reinstall the 8 -10mm valve cover bolts. Torque on these is only supposed to be around 4 lb.ft. DO NOT OVERTIGHTEN. You can somewhat feel when it is tight enough, plus the valve cover will stop compressing onto the head.
Note: If for any reason you have are having trouble getting the valve cover on, check to make sure the gasket has not fallen out of the lip. If it has, you need to remove the valve cover and reinsert the gasket before continuing.
Now attach the wire loom bracket over the top of the timing cover with the holes aligned you can now reattach the 2 – 10mm bolts that attach the timing belt cover to the top edge of the valve cover.
Now you will repeat the same steps for the front valve cover. Install the gasket into the valve cover lip, apply sealant to the head, install the valve cover and then reattach the 8 -10mm valve cover bolts & reattach the 2 – 10mm bolts that attach the timing belt cover to the top of the valve cover. This timing cover has 1 wire loom bracket that attaches with the rear bolt.
Now with the both valve covers installed and bolted down you will want to reinstall the vacuum hose attached to the right side of the valve cover, the hose connecting both valve covers, and the hose connected to the front valve cover. There is one more vacuum hose which attaches to the right end of the back valve cover and goes to the air intake.
Now you can reinstall the large black bracket (with the foam padding attached) behind the rear valve cover. There are 3 – 12mm bolts holding it on below the valve cover, you will have to work by “feel” here. DO NOT tighten these 3 bolts fully until after you have the upper intake manifold in place.
Lastly, reconnect the plug wires (remembering where they came from).
Here is the finished product! Be sure to check for any leaks when you start the car for the first time.
Now you can proceed to my Upper & Lower Intake DIY :biggrin:
Enjoy
-Ryloth
V6 Valve Covers (Remove and Reinstall) - PDF - Archived
Tools Needed:
Pliers
Ratchet
10mm Socket
12mm Socket
Enjoy
-Ryloth
