OK. I recently swapped my engine, and in doing so had to remove the lower strut knuckle bolts and pull the spindles back to remove the axles. Well when I first put everything back together, everything seemed fine... but a few days later, I started to hear a slight knock that sounded like it was coming from underneath the driver's side of the car.
Well I initially thought it was just the CAI rattling (maybe hitting the motor mount or inside of the wheel well), but upon further inspection found that both of my upper strut nuts (the center ones) were considerably loose. I mean - these things were supposed to have 50 ft lbs each on them, and they were backed out a few full turns a piece, with the driver's side being the worst at maybe or 6 or 7 full turns.
Now obviously re-torquing them solved the knock issue (go figure), but I'm just curious if anyone has ever heard of the top, self-locking nuts just randomly working themselves loose like that, be it from disconnecting the lower strut knuckle bolts or otherwise? And I'm absolutely sure I never loosened the top ones, so it just seemed a little "weird" that they would be that loose for no apparent reason.
