1 - 20 of 29 Posts
techn9ne2283
· Registered
Discussion starter · #1 ·
well as some of you may or may not know... i blew the amp (or should i say sub blew it) but anyways, heres my chance to get a new, possibly better one... i originally had a phoenix gold xenon 1200.1 to my jl 12w7. i want the best amp there is that would be perfectly compatible with my sub. jl recommends that my sub and box can handle up to 1200 watts rms. thanks for any advice or help you guys can give me.
my options so far is get a new same phoenix gold amp, or the jl 1000/1 amp...
at what load?
/edit- **** it, doesnt matter Orion 1200D if its @ 1-2ohms or Orion Xtr Pro 2500 if its 4 ohms
my guess is that its @ 1ohm so get the 1200D. i can get you one for new for 350 and a used for anywhere from 250-300 depending on condition.
mac
techn9ne2283 said:
hahaha.. you said, 'load'.............
that just goes to show you mac how little tech knows about this...........he probably thought you meant the load in his pants from when he was "wangin it"
Discussion starter · #6 ·
bwhahahhahahahaha.. you're a funny man my friend.. i was just being humerous....
and seriously tho... i really did laugh out loud
i know. and also....your sub didnt blow your amp.
also check last post for more input
yes, i was going to comment on that as well.........a sub cannot blow an amp.......im pretty sure its impossible.
techn9ne2283 said:
well thats what phoenix gold said.. shows how much YOU know...........
then enlighten us with your superior accumen on how exactly a speaker, that really doesnt make any noise unless pushed by an amp, blows the amp?
if I was you, i would have questioned as to how that guy has a job at phoenix then.
HTownTuscani said:
straight from the JL 12w7 manual:
what the hell is that?? and how the hell do you get 35 volts go a 500/1?
what kinda of wattage does the SUB take. i dont care about the jl amps. decent amps way over priced. Orion powns.
and yes y a sub cant blow an amp. it either wasnt gounded right or the sub was hooked up to it wrong.
mac
Discussion starter · #17 ·
so it was an install problem? and would this mean the sub is blown too? b/c when it happened, i heard a really crappy loud noise, then it smelled like crap for awhile.. then then next day they opened the amp and it was black inside on some parts.....
HTownTuscani said:
the 12 w7 can handle up to 1200 watts safely and is designed to optimally handle 1000....continuously.
AT WHAT OHM LOAD??????????
12W7 produces a 3ohm load....jeez how hard was that
get the orion xtr pro 2500
1200 X 1 @ 4ohm @ 12V input
so youll get in the area of 1300 watts with the car on to 3 ohms
then youll also be able to stick with this amp and run it at 1.5 ohm and get `2500 watts if you ever get a 2nd sub.
you got it...........could have not been wired properly or grounded properly. In either event the place that installed it should be buying you a new amp
1 - 20 of 29 Posts
