camshaft seal replacement?
1.2K views 2 replies 3 participants last post by  peachferrari
my 03 tiburon gt is leaking oil from behind the harmonic balancer/crankshaft pulley. took off the pulley to see if i could replace the seal but how do i go about that? Noticed the sprocket do i have to remove the timing belt to replace the seal behind it or am i missing something? need help if anyone can.:cautious:
Yes, timing belt has to come off as well as the crank sprocket, which hopefully isn't seized on like my last one was.
And a tool such as this one helps a ton to get the old seal out without damaging anything: Lisle 58430 Shaft Type Seal Puller https://a.co/d/34yLyXW
