So I have refilled my coolant resevoir for my supercharger like 3 times in the last month. What the hell is going on? Where is it going? I dont see it coming out of anywhere. help!
When your pump dries it will make a huge grinding noise and you will feel a big vibration. That's how I knew mine was empty.03Blk Tib said:Do you think it may be the pump? Also if I ran it dry for a for a few days is my pump f*cked?
Im still trying to figure out what to fix!kellydood said:Well then what has probably happened is the pump shaft seal on the pump failed, which would cause coolant to fill the pump and fry the motor. If not, your heat exchanger in your intake manifold could have gone bad, and started leaking. Either way, quit posting on here, and fix the damn car LOL....it's an easy fix.
