Ok, I have a 03 GT V6 and I'm getting ready to do my plugs and wires. I have around 63k miles on the car and was wondering if I should use the same gasket that comes off of the car or put a new one on...
I did just to try to make things a little easier. The worst part is taking the UM apart from the TB. I have an Injen CAI and taking the intake off of the TB just made it that much easier to get to the 2 bolts on the underside of the TB to take it off of the UM.This might seem like a stupid question, but the intake needs to be taken off to do the plugs?
Sorry for my ignorance, but I just bought my tib two days ago and haven't had much time to look into these things.
no, you don't HAVE to...you can just take the TB off of the UIM and remove the UIM without touching the intakeThis might seem like a stupid question, but the intake needs to be taken off to do the plugs?
I'm at work at the moment so I didn't get much time to look at the picture. Is that the spot where the stock resinator hose plugs into?I still need to know if the thing in the red circle needs something hooked up to it, because right now it doesn't. my car drives just fine but my CEL is on with the code P0113 "intake air temp. circuit high input". Hopefully moving the harness away from the plug wires solved the issue, but i'd still like to know if there is supposed to be a hose hooked up into that spot.
Nothing plugs into the IAT sensor or the thing i circled in red?nothing plugs into that
