I did all the bearings, and yes, they're all put on properly (i always take a picture when messing around with engine stuff to help me with the reassembly latter). I also did each bearing set one by one so i'm sure all the caps are placed correctly lol. And by notches, do you mean the tab insert thing from the bearings? I have them on like how the picture shows them, that picture off hmaservice? :3_wink:
Also, i'm turning the engine with a 3/8 ratchet with a 22 on it attached to a long iron tube, its around the same length as my 1/2 torque wrench, the car isn't the high off the ground so don't have that much room for a longer bar lol.
no if you oiled up the bearings that should be enough,,,
i have a 4cyl motor sitting in my basement that has been stripped down to a long block for about a year now and i can turn it by hand..
i think there is one thing we are forgetting here tho... you shouldnt be able to turn it by hand anyways, its really hard to turn the motor by hand when you are also turning the cam's
how is your timing belt and the condition of your cylinder head
Heads fine its the first thing i took apart to check the tappets since i knew they were an easier job then the bearings... ended up being the bearings anyways. :3_sadley:
As for the timing belt, it's maybe 3 weeks old, with maybe 2 weeks of actual use. And your motors is taken apart.. mine is in the car... with everything attached to it... lifted up in the air lol.
Also, a general question to you guys, I was doing some further looking on other forums while eating diner and ran into someone who said to make the engine turn by taping the starter (for a brief second) so that the engine can rotate a bit by itself. They said they did this on their car with every few turns of the bolts until they were at the proper torque and that it solved their issue. I wanna try doing this tomorrow but just wanna get a second opinion to make sure i don't mess anything up. :3_bier:
