1 - 18 of 18 Posts
smthrde
· Registered
I bought the Generation 3 PKG from HID Planet which consisted of
(2) Hella LVQ-212 G3 Ballasts
(2) D2S HID Bulbs 4300K
(2) Ballast Covers/mounts
(2) Ballast connectors
Then i also bought the Wiring harness from Xenon Depot for the H7... very high quality
The pars cost $410 to the door, but you get what you pay for...
im eventually going to install Hella Bi Xenon projectors to finish the retrofit.....
Pic of the balast and bulbs...the pic is from HIDtech, but it is the same.
ill post pis of the beam and color when it gets dark out....
I mounted the balast to the bottom of the head light with heavy duty dbl sided tape and 1/4" self tapping screws with silicone......
Discussion starter · #6 ·
tibboy2003 said:
what pic?
and I make a relay harness that's alot better than that mang.
r u sure??? have you sever seen this harness??? ive never seen the one that you make....
Hey man, hit me up when you do your retro. I can give you some tips. Also, you should weather seal those ballasts since they will be getting wet when it rains. The ballasts are not weather proof. Water can get inside.
Discussion starter · #18 ·
teacupsunderfire said:
what is the relay for? and anyone know where to fine 10k hid setup for the tib 04?
For the HID... the tiburons elecrical system is not designed for the current draw demanded by the HID... there are many threads about this that can explanin it in detail...
1 - 18 of 18 Posts
