What does the stock flywheel weigh? In a V6 5spd
MY GOD YES!!! =DDam so getting like a 10 or 11lb flywheel you will feel a diffrence ya think ?
Chromoly is just as light and stronger go chromoly if you can. I am using chromoly and I think mine is only 12lbs. It's just as light as aluminum.Chromoly is stronger than steel, but it weighs less, requiring less material for an equally strong flywheel; thus weighing less than a stock steel flywheel.
The Aluminum flywheel is quite light, allowing the engine to rev very quickly. I haven't read much about the Chromoly flywheels available for the Tiburon, so i'm unsure if they are heavier than the common 10 pounds you would get if you went with Aluminum. The downside however is that Aluminum is much weaker comparatively to steel, and thus would have a shorter lifespan.
I'm sure if you looked up "chromoly vs aluminum" on google, you could find much more information about this than I could ever tell you. =)
Unless they specifically say that it's a combo deal, it will only be the clutch.so when you buy a new clutch, do you also have to buy a new flywheel, or is that already part of buying the clutch?
mine is clutchmasters fx300 clutch and fidanza aluminum flywheelWhat kind do you have? I dont want to have added noise from a new flywheel..
