jamie said:
can u explain the fitment issues a lil more?
I bought one a while ago, and believe me it sounds and looks amazing. The install was a real PITA mainly because of 2 reasons. 1) the holes on the pipe that connect to the the cat aren't tapped big enough, so you need to widen them. I tried doing it by hand with a file for a while which didn't work to well because the stainless was soo thick, so I got someone with a drill to help me widen up. It went real quick with the drill and fit on good after that. The second fitment issue is that the right exhaust tip is like bent inwards so it touches the inside of the cut-out. What I had to do I took it to a muffler shop and they just the pipe up with a blow torch and bent it. Although a little part of the pipe does look kind of ugly it solved the problem. But bending this pipe was no easy task, the freaking stainless on this exhaust is THICK, it took the guy a good hour, and alot of heat to bend the pipe lets say 1-2 inches. But in the end its a great exhaust, sound great, looks great, and a great price. You won't be dissappointed I PROMISE. I do recommend taking it to a shop to install though just because with the little fitment issues its just easier, and you'll have to take it there more than likely to get the pipe bent. Anyways thats my little review haha. ENJOY!!
