Anyone know anyone that has done one of these? For years they have sold natural gas conversion kits and I actually found a place that makes conversion kits that use hydrogen. It should be legal since h2 produces no emissions.
some videos about it:So what does the Hydrogen Boost do? It's not magic, it's SCIENCE. You fill the system up with Water and the Hydrogen Boost separates the Hydrogen from the Water. It then takes the Hydrogen and delivers it to your fuel injectors along with the gasoline. Hydrogen combusts with the Gasoline inside the engine therefore creates a more efficient use of the gasoline. The combustion creates a more efficient way to power the vehicles engine. Since Hydrogen burns hotter then gasoline, the mixture between the two will require less gasoline to power the actual engine.
Hydrogen does not damage or ruin your engine in any way since the combustion is controlled by the vehicle's ECU. The ECU will simply not let anything happen with your engine that would damage it in anyway. Why haven't the automakers adopted this before? Well after 20 years they are just starting to, introducing Honda Civic FCX.
You don't have to wait for the auto makers to come out with Hydrogen cars, convert your car now. The Hydrogen Boost will convert your car into a Hybrid which will run on Gasoline and Water! You fill up your water tank every 325 miles - 1200 miles on bigger systems, that's approximately once every time you fill up.
In addition unlike our competitor hydrogen fuel conversion system, ours is guaranteed to work. We promise 10MPG or your money back. Why are we so confident in our system and our competitors are not? Because adding Hydrogen into your engine will not increase your MPG unless three things occur:
Vehicle ECU is configured to allow the extra combustion from the hydrogen to enter or it will completely reject it.
The oxygen sensor must be configured with a special circuit board that will accommodate the hydrogen.
The Hydrogen Boost Fuel Conversion must produce enough Hydrogen per hour to accommodate your specific vehicle.
Our Hydrogen Boost system are not universal, we have designed and tested each system for every specific car model. Our system come s with 2 ECU Circuit boards that will reconfigure the ECU and the Oxygen sensor for your car. It is a Bare bones PC boarded EFIE circuit (Electronic Fuel Injection Enhancement) (Size is 1" x 2 ½"). The board is complete and ready to install with all the wiring for 12 volts dc input and the oxygen sensor signal input and output that goes back to the vehicles computer. There is a switch to put the unit IN operation and OUT of operation. It has an on board red and green LED that shows when IN or OUT of operation. The Oxy Comp-1 comes calibrated and ready to install. All components are of military specs. Has on board voltage regulation so that the offset voltage that you set is extremely stable and will not drift. Also has an on board relay that the oxygen sensors signal is switched threw.
No sir, it is made from hydrocarbons such as natural gas and this is achieved by separating the hydrogen from the rest.And, currently, as croat pointed out, most hydrogen is created via burning oil... so in our current style of making it, a hydrogen car won't change anything, fuel price OR emissions, since to make it, the same resource is being used, oil. When they start making it via solar or wind power, then thats something to talk about.
Hydrogen can be generated from natural gas with approximately 80% efficiency, or from other hydrocarbons to a varying degree of efficiency. The hydrocarbon conversion method releases greenhouse gases. Since the production is concentrated in one facility, it is possible to separate the gases and dispose of them properly, for example by injecting them in an oil or gas reservoir (see carbon capture), although this is not currently done in most cases. A carbon dioxide injection project has been started by Norwegian company StatoilHydro in the North Sea, at the Sleipner field.
