miguelvts
· Registered
Discussion starter · #1 ·
Hi, I have a L4 2.0 VVT and I wonder if the CAI of the 2.7 V6 is valid for the L4, ie if the throttle body diameter is the same in both.
I have located a CAI for the V6, but I would like to know first if I would.
Maybe with a rubber reducer could be installed not you think? :3_nosthum
my AEM intake for V6 was 3 inches in diameter, but had a rubber coupler at the throttle body to become smaller, so it should work the same with your I4, if the MAF is also 3 inches
Discussion starter · #3 ·
Well not that big is the MAF of 2.0, did not know there were different sizes.
I'll see if someone with a V6 in Spain can test my MAF diameter so they compare with mine.
Thanks
you could get rubber reducers for the MAF as well, if you want this V6 intake
