1 - 6 of 6 Posts
I'm gonna go ahead and ask it.. did it come with instructions?
Also here's a link. It's not at all for a tib but it may give you a general idea of where to start in getting them off.
And if all else fails... bump for a Vet's assistance.
Let me know how it goes. I was thinking of buying them myself but I just haven't gotten around to it. All I can say (from someone how simply removed the little plastic pillar collars (thats what I'm calling them) that 'seem' to connect the mirrors to the door it seems pretty straight forward (minus the wires and such). The little collars just pop off easy as cake (mine did at least, because I just painted mine :)), and there should be like 3-4 bolts holding the mirrors in place. Mind you though, the collars only cover the front, side, and rear of the little pillar. Look closely at the space between the inside of the mirror (the part that actually faces the door), and the door itself. You should see at least where they separate. I would recommend a screwdriver/prying tool because it is a plastic piece, and you'll need to pop it off. It's actually pretty easy because there isn't a lot holding it in place, but it does like to snap back easily.
Bump though for luck if anyone else can help more.
u jus take the old ones off theres a cover that pops off on the outside..theres a few hex bolts mirror comes off...glass pops out with some pressure..plastic inner poeces screw out then jus reassemble the new mirror..as for the wires for the turn signal idk
Discussion starter · #6 ·
ya man .. they dint come with instructions thats y im askin..lol...
Let me know how it goes. I was thinking of buying them myself but I just haven't gotten around to it. ..... .....it in place, but it does like to snap back easily.
thanks yall with the helpful tips... but im having the bigest problems on the wiring part, i was thinking to connect the bottom led to the dor courtesy light
and the top leds to the turn signal...
i just haven't had time to install them, been too bus with school and work..
.... when i try to install them and if i succeed ill let yall know
1 - 6 of 6 Posts
