i rolled and pulled my fenders today and also did the camber -1 on rear fenders. when installing the hub adapters 20mm, everything was going as planned. then i hit a snag, when placing the wheel on, the studs did not allow the rim to sit next to the adapter. my question is should i buy the 30 or 35mm adapters? i dont know if ichiba makes that size of adapter. the reason i want to buy a bigger adapter is to hide the existing studs because i need clearance or should i just stay w/out adapters? my setup is xxr 521 35 offset, 1.6 inch drop, 215/40/18. where are the wheel gods when you need them!
