vht nightshade removal
1.2K views 7 replies 6 participants last post by  Brody602
ok i put the nightshade on because i was bored, and for a bit it looked good to me, but now i feel like it's a rather stupid idea and would like to know if you guys knew any way to remove this stuff from your lights. i head carb and choke cleaner works well, but i would like a few more opinions
#5 · (Edited)
Paint remover doesnt really work well with this stuff for some reason, your best bet is gasoline, with a good microfiber cloth, don't over do it with the gasoline, im pretty sure if you put way too much you may damage your light housing (plastic lenns) and I wouldn't advise you to try anything BUT gas due to the fact that most removers/cleaners are more corrosive then gasoline.
Cheers
Paint remover doesnt really work well with this stuff for some reason, your best bet is gasoline, with a good microfiber cloth, don't over do it with the gasoline, im pretty if you put way too much you may damage your light housing (plastic lenns) and I wouldn't advise you to try anything BUT gas due to the fact that most removers/cleaners are more corrosive then gasoline.
Cheers
Oh is that so?
