41 - 53 of 53 Posts
Discussion starter · #41 · (Edited)
What brand/model drag radials do you have?
Just an awesome run sir! I'll get you added ASAP.
You are really making work for me what with you constantly requiring me to update your record N/A time......LOL.
GREAT job to you as well as T.C. :)
I'm from Davie, I live right next to Nova Southeastern University.
actually with the radials I launched at 4,500 rpm and revved the motor to 7,300 (had TC make the limit higher so i can rev to 7,300 without hitting a limiter)
cool **** next time i come down that way you should show me the beast :3_winkthu
I was using Toyo Proxes RA1's
yeah man, just let me know when you're coming in town.
Nice run, scary, the thought of what you're capable of with FW, clutch, UD pulley, motor mounts! Gotta get you up on my dyno to compare to the original #s, just fer grins!
dang..13s!!! boost that beast and crank the boost up like crazy!!! u got 11s :p
yes malogus made something around there, but on the small crower cams. You will get better peak horsepower off the smaller cams with stock heads, however the reason I am running better times is because I am carrying the power all the way to 7300 rpms, whereas the crower cams die out in power slowly.
Yeah, here you can see the peak power is around 6700rpms and then it slowly drags out.
DeShark, congrats man I only wish I could try this summer to see what I could do in some cooler temps and a lower altitude. My best time was 14.12 last year but since the closest drag strip is about an hour and a half away, I don't get to see it much.
hey baron whats your lift on your cams?
41 - 53 of 53 Posts
