Hello, I'm rebuilding the 2.7-liter engine in my 2008 Hyundai Tiburon AT and have the following questions:
What other advice could you give me?
The parts I replaced are as follows:
Everything is original and new.
Thank you very much for your help.
PS: In case you're wondering, buying a used engine with God knows how many miles it has or what problems it has was more expensive than rebuilding the engine with new, original parts.
- Should I restart engine maintenance from where I left off (90,000 miles) or from zero miles as if it were a new car?
- Is it advisable to use mineral oil for the first 1,000 miles? I'm considering a Chevron Supreme.
- Camshaft
- Connecting rods
- Oil pump
- Engine hydraulic lifters
- INJEN Cold Air Intake
- Timing chains
- Crankshaft
- Cylinder sleeves
- Timing belt kit
- Original gasket kit
- Radiator hoses
- Connecting rod and main bearings
- Pistons
- Radiator (I'll be using a Toyo)
- Rocker cover
- Thermostat and entire coolant system
- Cylinder head bolt
- Inlet and outlet valves
