2nd time buying rims lol...need help now
980 views 20 replies 14 participants last post by  rls608s
these wont fit right...it says 100 mm between lug holes. also why would it say that...im under tiburon 17 inch:
http://www.discounttiredirect.com/d...com/direct/findWheelDetail.do?yr=2004&wd=17&pc=76175&rw=7&bp=5-114.3&vid=007405
http://www.discounttiredirect.com/d...direct/findWheelDetail.do?yr=2004&wd=17&c=1&pc=51008&rw=7&bp=5-114.3&vid=007405
http://www.discounttiredirect.com/d...m/direct/findWheelDetail.do?yr=2004&wd=17&c=1&pc=74360&rw=7&bp=5-100&vid=007405
all three read the same. also which of the 3 do you think you look bettwe on a tib. please make sure they fit...i dont wanna make my last mistake
well, i can't give you an answer for fitment, but the second set would be the nicest.
http://www.discounttiredirect.com/direct/findWheelDetail.do?yr=2004&wd=17&pc=76175&rw=7&bp=5-114.3&vid=007405
http://www.discounttiredirect.com/direct/findWheelDetail.do?yr=2004&wd=17&c=1&pc=51008&rw=7&bp=5-114.3&vid=007405
http://www.discounttiredirect.com/direct/findWheelDetail.do?yr=2004&wd=17&c=1&pc=74360&rw=7&bp=5-100&vid=007405
yea i love the MB and the lip is crazy nice......BUT WILL IT FIT? the last time i did this i bought rims amd they didnt fir on the dam car lol.......and what tires do i get? is this a good size...the website says its my stock ones 215/45-17. one more question.....if i order both tires and rims for discount tire direct....will they put the tires on the rims for me?
http://www.discounttiredirect.com/d...14.3&vid=007405
These are the exact same size as the stock 17 Tib rims, they'll fit fine.
These will fit fine also.
http://www.discounttiredirect.com/d...-100&vid=007405
These will be fine also.
Any of these rims will work just fine as long as you get the right bolt pattern. If you're unsure about what size the Enki comes in then call Dicount and ask them. With any of these rims you should go with either the stock size 215/45/17 tire or a 225/45/17. When you order them you can pay a little extra to have them mounted and balanced before being shipped.
I personally the the MB looks the best out of those three.
Enkei's don't look as cheap as the others and is probably the lightest of the three. I once looked at MB's and they were pretty heavy rims. Another thing to consider, if you purchase the Mb's, which are a discount-tire direct exclusive, chances are if you scrape up a rim they'd probably let you buy just one rim if needed. (thats if they don't allow that)
