1 - 11 of 11 Posts
goke313
· Registered
Charging System Warning Light
Oil Pressure Warning Light
Parking Brake/Brake Fluid Level Warning Light
Malfunction Indicator Light
2003 base model
I'm LOST+Confused+Desperate+still on college student budge aKa Broke
drove from Buffalo to Queens,NY
1st the Malfunction Indicator Light was on....friend told me to put coolant....after putting it Malfunction Indicator Light is off
then i find out the transmission wouldn't get out of Park until i forcefully did pushed it to Neutral or Reverse....it wouldn't go on Drive {car did reverse}
struggled to put the car back on park....(it's place on there but the 'P' isn't displaying on Trans axle Position Indicator Light)...even struggled to get the key out
now my car won't start the following 4 indicator lights are on....help
All those lights are on because you haven't started the car. Like if you just put the key in the ON position, those lights would be on. The transaxle range switch will only allow you to start the car in park or neutral. Since your having trouble getting it in park that's probably why it won't start. Try shifting to neutral and then try and start it.
Discussion starter · #4 ·
lets say if i can't start it on neutral....what then?
1 - 11 of 11 Posts
