1 - 14 of 14 Posts
hammerhead
· Registered
http://worldwide.hyundai-motor.com/innovation/safety/bas.html
The brake assist system operates in combination with the ABS. It was developed so that greater braking force can be generated even when little pressure is exerted on the brake pedal in an emergency situation. It assists female and senior drivers to get the emergency braking they need while activating the ABS under ordinary road conditions.
As shown in the graph, the same braking force is generated (with or without the BAS) when the pedal is engaged within the regular braking range. In the emergency braking range, however, greater braking force is generated (with the BAS).
* Pressure on brake pedal to generate "A"
amount of braking force.
- "B": Conventional brake system
- "C": BAS
In other words, the driver can exert less effort (equal to "B" - "C") to receive "A" braking force.
BAS can identify an emergency braking situation and will automatically initiate maximum brake pedal pressure for full braking power thereby reducing the braking distance.
http://worldwide.hyundai-motor.com/intro/news/new_030514.html
Discussion starter · #4 · (Edited)
well as the new elantra has it, I thought the more upscale Tib should have it too, no?!
EDIT: no I dont think we have it. the mercedes SL 55 AMG has it, the mazda 3 and a lot of other cars but the tib does not...
Discussion starter · #10 · (Edited)
well but ABS is not the same as BAS...
actually I read that the tib facelift which will be presented at the paris motorshow end of september together with the new sonata will have ESP (electonic stability program)...codeveloped with Bosch
actually I read that the tib facelift will have ESP (electonic stability program)...codeveloped with Bosch
KDM specs or US specs....the facelift is cool and all, but we dont know what is staying there or coming here
1 - 14 of 14 Posts
