Hi guys,
Any thoughts on my $400 purchase? Would anyone recommend additional parts for the install?
The F1 Racing Xtreme® pressure plate is made from the forged ductile iron (3X stronger than the conventional cast iron pressure plate) to ensure consistent clamping force and the extra long life. The 5 puck disc features high capacity sprung center hub for a precise and non-abrupt clutch engagement. The 5-puck copper ceramic (also known as 'MIBA') disc features high-coefficient friction pads that are resistant to slippage and burst. The F1 Racing Xtreme® pressure plate features special single diaphragm design to increase clamp load. It features induction hardened diaphragm, CNC machined castings, stronger drive straps and rivets. F1 Racing Xtreme® pressure plate provides smooth and precise feel with easy modulation. All F1 Racing pressure plate is load tested on a special testing tool for quality assurance.
F1 Racing Xtreme® FRX300 Clutch kit and Flywheel package includes:
F1 Racing Lightweight Chromoly Flywheel
•F1 Racing Xtreme® Heavy-Duty Pull-Type Ductile Iron Dual Diaphragm Pressure Plate
•F1 Racing 5-puck sprung copper ceramic disc (8-1/2", 20 spline)
•Release Bearing
•Alignment Tool
•Installation Guide
Horsepower Rating: 370 HP / Torque Capacity: 349 ft/lbs
F1 Racing Lightweight Chromoly Flywheels are made from 4140 one-piece forged chromoly steel. They are specifically designed to reduce weight and inertia for better engine response. Most incorporate special design features to enhance the air flow to improve the cooling of the clutch. The ring gear teeth are milled onto the flywheel unlike an aluminum flywheel where the ring gear is pressed onto the flywheel which has the possibility of separating from the flywheel. All F1 Racing Chromoly flywheels have passed engineering tests to 12,000 rpm.
•Ultra heavy-duty and weighs only 9.6 lbs
•Meets or exceeds SFI 1.1 specification
•Made from 4140 chromoly steel (2X stronger than billet steel)
•F1 Racing Lightweight Chromoly flywheels incorporate special design features to enhance the airflow for improved clutch cooling
•F1 Racing Lightweight Chromoly flywheels work with every clutch including Exedy, ACT, Fidanza, Clutchmasters, and other OEM clutch kits
•CAD designed, CNC machined and computer balanced
** I'm going to repost the original photos because of those PhotoBucket w*kers. *
•Release Bearing
•Alignment Tool
•Installation Guide
