Gill removal?
1.6K views 8 replies 4 participants last post by  SEAN
How in gods name do you get off the gills. I tried to remove the wheel well piece and it does not come out, then I tried the whole fender and it is a b*&%$#, so how do I do it. If it is the fender how do you get it all the way off.Thanks all.
you have to take around 2 or 3 of the plastic screws out on the wheel well plastic liner on the back side of the tires..you should see a big piece of foamy looking stuff between the back of the fender and the gills...pull it out...there are 6 clips that have to be squeezed with a pair of pliers all by feel...as you pop them out put a piece of cardboard under the gills as it breaks away slowlly from the fender...otherwise you might have them pop back in accidentlly...just take your time and you will be fine...it akes a bit of time because you have your arm squeezed in between the gill and liner and doing it all by feel...good luck and hope this helped
Its easier if you remove the foam pice near the door and go fron that side, you can actually see what your doing from that side.
Red Blaze said:
Cool thank, I will probably try both sides.
Just open your door and look into the frotn quarter panel, you'll see the foam piece you need to remove. Remove it and you'll see the little green clips that hold in the gills. You'll need a pair of needle nose pliers to squeeze the clips so you can back them out of the holes.
This is a view looking inside the fender after removing the foam piece, drivers side
You'll need to put some outward pressure on the gill once you have a clip unhooked so it doesn't click back in place, I used a small spatula
This i what it looks like when removed.
