21 - 23 of 23 Posts
12 a.m. In Orlando, and a Stella sounds good! Cheers from another newbie.
Not to many tibbs in my area
I had a similar problem... my tibby was losing coolant slowly and no codes were popping. It was pooling around my slave cylinder and underneath my upper intake manifold.. which was completely puzzling. It eventually got worse and I was concerned it was my water pump (as it looked like it was pooling under it). Took it to a shop and they replaced the gasket on my thermostat housing and 2 other gaskets close to it (also replaced my thermostat "just in case" and the upper radiator hose) and no more leak. Have to say I'm glad it wasn't the water pump.. they saved me a couple hundred bucks!
21 - 23 of 23 Posts
