My engine seems to run somewhat correctly now. There's a bit of a quiet, almost rod-knock like rattle that starts up after the engine enter closed loop, and it goes away once the oil is brought up to temperature.
I've filled the sump with Valvoline's fully synthetic 5W-30, and I've kept the low-restriction K&N HP-1008 filter.
My cheapo oil pressure gauge (a Depo DualView rebranded as RaceSportPerformance (lol) which I'm not treating as a scientific instrument but rather a guideline with at least some amount of internal consistency) reads ~6.5 bar or ~94 PSI at startup, if I remember right, and once at an operating temperature of ~90 °C (or 194 °F) hovers between 1.2 and 1.3 bar (~17.5 and ~19 psi) at idle. I don't know how much it's at cruising, as the car has not yet been MOTd, though ~3 bar (or ~45 psi) seems likely based on testing thus far.
ANYWAY, I tried looking for an official pressure spec. 1.2 bar seems a bit low, though the engine isn't making any worrying noises once it's up to temp. The only mention of an oil pressure spec in the shop manual says "oil filter ... engine oil pressure 7.3 psi or more with oil temperature between 75 and 90 °C", which is just 0.5 bar, and that really seems low.
What's your experience? Do you know of an actual pressure spec? Should I disregard any readings as long as the low oil pressure light is off?
Edit: hmm, after re-reading BWTech's thread it seems his oil light started flickering around 6 PSI on his gauge, so I guess that 7.3 psi might really be the correctly specified minimum.
