Ok heres my situation, I have $6000 CDN to spend on my engine in the spring. I need some help from boosted guys. I am getting the Alpine Intercooled kit, I would like to have the Unichip tuned to 15PSI before it gets to me. There are little things I would also like with the kit though like
-Fidanza Flywheel
-Clutch (need help on this one, I like ACT but am open to suggestions becuause I had the Ebay crap before)
-OEM timing belt kit with water pump replacement
-Boost controller (not necessary if I dont get the 15PSI flash)
-BOV
-2.5" or 3" exhaust, I think 3" would be fine, straight through metallic core cat no resonator with OEM tips (hogged out of course to fit over larger pipes)...will the stock exhaust work with 12PSI
-Springs (had coils before, so I figure Tein or Drop Zone)
-Gauges and pillar (Boost, oil press, AFR) I would like Defi gauges but will settle for Autometer due to cost...BRR where did you get your 3 pod pillar?
I think that I should just get the kit as it is for now and build later, its funny how fast things add up when you look at the big picture. If anyone has any suggestions on a setup I would appreciate it (this is where I poke BRR and dmdicks)
-Fidanza Flywheel
-BOV
