1 - 6 of 6 Posts
bjm2020
· Registered
Discussion starter · #1 ·
Can anybody recommend some springs for me? I have 18's and I plan have a Genius Body Kit also at the end of this month! I was thinking about the Eibach sportlines but I am wondering if it would be too much of a drop?
its a nice drop, but preety agressive from wat i heard..u definetely will need struts fast..so u might as well get the coilovers...id go with the pro..good drop, i doubt ill need to replcae the struts
i am in the same boat, i just ordered some 18x7.5 rims and i want to drop my car some but not too low, EIBACH PRO KIT SPRINGS is what i plan on going with, i will be getting a body kit on soon also... but what i need to know is will i need to buy other suspension items? or will my stock be fine for now? can anyone reading this help... thanks.... :3_winkthu
I couldn't figure out if you had a GT or not. If so, you can get away with a small drop ~1" with stock GT springs. If you decide to go with something like the Sportlines, you're going to have to look into upgrading the dampers as well, because as Styles said, its a more aggressive drop; simply a lower drop. I wouldn't go too low, because then you'll have to look into other suspension areas such as camber adjustments, etc.
Discussion starter · #5 ·
I don't have a GT, so I am eventually gonna have the get more suspension items anyway. So since I have 18's and a kit. Will I have a chance at having rubbing issues with the sportline's?
Does anybody know what springs Telisa27 has on his Tiburon with the Genius kit?
1 - 6 of 6 Posts
