Power Locks and Air Bag Lights
1.6K views 10 replies 3 participants last post by  bloodycliff
hey, so when i put my door back on after a failed lambo experience (i had to learn the hard way) my drivers side door would not lock with the key remote, but it locks when i push it, and with the key, and it also parelle locks the other door when pushed or opended.
so i bought a new lock acuator, and i still have the same problem, so is my problem electrical ( i did extend the 26 wires in the door jam from the lambo job)
also today all of a sudden my airbag light came on, i just had new speakers put in, and i just messed with the speedo gague ( overlay gauges lol) i read those could cause it, but most likely it was the seat belt sensor, but i will be damned if im gonna pay the stealership 105 for diognostics plus parts then labor, and to clear the code.
i also know i can just pull the incidator fuse (which i will do if i can't find a cheap solution to the problem)
the car is an 04 gt auto
thanks
cliff
bump for my car (which now has pissed me off to the point where i want to sell it....gawd i would like a gto or gen coupe....errrrr....bwm...mabey
my best advice would be to take the car to a shop or napa or somewhere where u can get a scan tool on the sucker. find out what the air bag code is, it should tell you if it is a seat belt or something more. and for your door lock i would check your wiring maybe something have been pinched like the signal from the key fob.
hope this helps
andrew
im gonna bump this...so i replaced the lock actuator, hoping that there was something electrically wrong with it, and the problem persists...who would i go about checking the power on the lines to see if power it getting to the actuator?
